wierd speaker problem
  • 2
eddiemac01
excuse my simplicity i dont know much about car audio.
Im using my phone to play music through my car stereo using the aux port. it used to work fine up until about two weeks ago when the sound started to only come out of the right speaker. this was just when using aux though. cd's and radio worked fine. i figured it was probably the cord i was using so i replaced it. when i turned it on the sound only came through the LEFT speaker. no clue whats going on. any help?
It sounds like the jack on your head unit has an issue. The contacts inside could be dirty, corroded or there could be a loose solder joint. You might have some luck with working the jack in and out of the head unit while rotating.
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
134
164
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
866
eddiemac01
eddiemac01
New Jersey
burnsy1
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
