why this amp wont work on one sub
Pioneer 1-Channel Car Amplifier (GM-7100-M)
# Of Channels 1
1 OHM Output Power - Full Range Info Not Available
14.4V Dynamic Power At 2 Ohms Info Not Available
2 OHM Output Power - Full Range 360 Watts
4 OHM Output Power - Full Range 250 Watts
Bass Boost Yes
Bridgeable Yes
Bridged Power At 2 OHMS - Full Range 360 Watts
Bridged Power At 4 OHMS - Full Range 360 Watts
External Bass Control Capable No
Fuse Rating (Amps) 25 Amps
High Pass Filter No
Included In Box Screws, Manual
Input Voltage 13.5 Volts
Low Pass Filter Variable
Mosfet Switching Yes
Overload Protection Yes
Product Dimensions 43.5(W) x 11.0(H) x 37.8(D) cm
Product Weight 5.7 kg
Protection Indicator Yes
RCA Inputs (#Pairs) 1
RCA Outputs (#Pairs) 1
Screw Type Terminals Yes
Signal to Noise Ratio 100dB
Smart Engage Turn-On No
Speaker LVL Inputs Yes
Total Max Power 800 Watts
Tri-Mode Capable No
Warranty 1 Year Parts & Labour
i have one sub , infinty -350 watt rms
It will work on one sub. I don't know who told you it will not. Just make sure your sub is around 360 rms power and able to be wired @ 2ohms. Like a DVC 4ohm sub or SVC 2 ohm sub.
mohsinkhan35
mohsinkhan35
Montreal, QC
mohsinkhan35
