yowhobedat
i installed my sub today, and theres an annoying whining noise. with the radio on or off, its still there. Any suggestions on what it might be?
can you further explain how you used the rca's? does your stock radio use the stereos speaker output as the signal wire for the factor amp? if you cut the ends off the rcas and spliced them into the wires, you may be using a high output signal on a low level input on the amp. this may be the issue. also its the only thing that has changed since your last install.i spliced my rcas into the stock amp inputs. i didnt use a loc. just spliced them together. the hu is a stock nav. for a genesis coupe. i dont have any pics at the moment. any help is apprecaited
