Which Tweeters and How Much Power
Alright done the measuring and 6.5's would require cutting which I am not willing to do on this car, if it was something I cared less about I would go for it. But I am getting a 6.5 inch sub to go behind the rear seats on the backboard which will help make up for the lack of mid bass, I hope... Any 5.25's you would recommend other than Crescendo, I am going for sound quality afterall. Alpine makes some nice looking once, fairly spendy though thanks to the brand name.
type R and X is mediocre. Image dynamics have a pretty **** good set with the CXS 5.25 set.
Alright thanks for the recommendation. Also, one final question, with a 5 channel amp (1 higher output for the small sub and 4 channels for speakers), does it matter if the sub is wired to the same ohm rating as the speakers if they're separate connections? Or is essentially a 4 channel and 1 channel amp in the same box? I really appreciate all the help you've been giving me by the way!
You need to look up the specifications of each different 5-channel amplifier. Most of them are stable down to 2 ohms on the subwoofer channel. In some exceptions you can use a 1 ohm load.
Alright thanks. Yeah I was mostly just making sure that the Subwoofer and the speakers don't need to be wired to the same ohm rating (since they're different connections I assume they don't need to be).
planedrop
planedrop
Portland, Oregon
planedrop
