Which one???
disturbed471985
I know its an audiopop but i have heard good things about this series just not this amp. 17" long
AUDIOPIPE CAR AUDIO AMPLIFIER 2500 WATT 4 CHANNEL AQX-360.4 784644414453 | eBay
I can get this alil cheaper. Cant find the length on this sob..
SOUNDSTREAM DTR4.680 CLASS D 680W CAR STEREO 4 CHANNEL BRIDGEABLE AMPLIFIER | eBay
Tossing this one in there. 15" long
CADENCE ZRS-C9 600 WATT RMS 4-CHANNEL CAR AMPLIFIER AMP | eBay
Hate the terminals but its in running. 10" long
http://www.ebay.com/itm/NEW-Massive-Audio-NX4-800-Watt-4-Channel-Mini-Amp-NX-4-Nano-Amplifier-/320916874270?pt=Car_Amplifiers&hash=item4ab822e41e
Maybe??? Dnt know much about it yet but its within my range. Just waiting on more info..
Solid Audio F47
I dnt think the cadence will do rated based just on its fusing. I am pretty sure the SS does close if not rated the AP i have no clue about. The massive heard good heard bad so idk but its small which is a big plus. Solid Audio unsure of at this moment. Crossover selection matters none as I run active via my HU. As u can see low budget is my shortfall on this one but I need something so what yall think? Owned an mbq 125.4 but room does not allow for it so no go for that one..
Not bad since I can talk him down. Only thing is length 17" is right on that fine line of fitting and not fitting. Will call to see how low he will go and go from there. TY
good luck. I happened to be checking out CL earlier this morning and saw it..Looks clean, and like you said, maybe get it less and see if it fits and maybe a demo b4 u buy.
No doubt it will be tested in my car before I buy. If I can get down to 150 I may go for it but the Massive being so small just gives me so much more room to wrk with.
160 would be a good deal for the diamond, but that cadence specs better of the ones you mentioned earlier, at a glance....and it is being sold as new, unopened.
Its just to long..... I am thinking NX4 as it gives me more room to wrk with. The cadence would wrk but I just dnt see it doing rated.
I have one of these left from tearing out my suburban system last week (I sold my suburban) and you can hook it up and try it....if you would meet me half way..say, Waskom?
Avionixx AXA.440.4
Specs @ 12.5v:
Class A/B amplifier
RMS Power @ 4ohm,
RMS Power @ Bridged 4 ohm
RMS Power @ 2 ohm,
Power Bandwidth (Rated Power -1dB) 15Hz - 30kHz
Frequency Response (+0/-3dB) 5Hz - 70kHz
"A" Weighted Signal to Niose Ratio >-90dBA
Channel Seperation >60dBA
Damping Factor >200
Variable Input Level 150mV - 6V
Variable Frequency Bass EQ 25Hz - 80Hz
Controlled Electronic Noise Suppression "Cens" Yes
Variable Low Pass Crossover Filter 50Hz - 250Hz 12dB
Variable High Pass Crossover Filter 50Hz - 250Hz 12dB
Double Sided, 1Oz. Copper Clad FR4 board Yes
Overload Protection Yes
Short Circut Protection Yes
DC Off-Set Protection Yes
Thermal Protection Yes
Fuse 2 x 40A
Heat Sink Dimensions - Inches 13 7/8x 9 7/8 x 2 1/4
Heat Sink Dimensions - Millimeters 352 x 251 x 57
Weight 12 Lbs.
disturbed471985
disturbed471985
Greenwood, La
BIGJEFF64
