Which is the best amp !
Taramp's Bass 12k-
Putting out over rated.. way over rated.
Rated to put out 12,000w at 1ohm at 14.4vDC at
Produced- 13,290 VA at 1.03ohm at 13.86vDC at
Bass line can also be wired below 1ohm.. Try to get approval by SD to do that.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif They still aren't there yet.
Imagine what our Bass 15k, BAss 30k or our SPL 40k does //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I will tell you 1 secret about the SPL 40k-
The prototype produced 30,000 VA rising to 0.98ohm at 9.9vDC. Hellacious beast.
SD over other Brazillian imo.
Those SD evos and powers are nice
until you actually touch em, flimsy plastic heatsink. At least taramps is semi flimsy aluminium heatsink.
thanks guys ‘ bass 12k would be nice i could run at at 2 ohms which i think its to much for my 2 sundowns X-15s lol but who cares ...
when will the MD be out ? theres a chrome and simple one
and why go with taramps model bass it has better components ?
i liked the soundigital bass 8800
doing a 6th order soon ‘ on my f150 but i also want to change subs and get 2 zv5 15s idk yet on subs
No, run them at the lowest impedance you can and just set the gains lower, only use as much as you need to get the most out of your subs. Dont run sh*t at a higher ohm load, that normally leads to clipping, because you wont be satisfied with the output. Box rise is a b*tch.
12k evo is rated at 12k at 12.6 volts
Not sure who would buy power 8k rated at 14.4 for same price.
Thd is good on both amps but .09 evo .015 power
1250 amps fuse rating on evo and think 800 on power 8k
Both amps 1000 dampening factor
I've never seen a rating like that in car audio.
Thought the old ppi power class at 500 was among one of the best dampening ratings in car audio.
Both amps 1000 dampening factorI've never seen a rating like that in car audio.
The Mosconi Zeros are higher than that. Not sure how it really affects performance after a certain point.
For the Zero 1 this is what the spec sheet says:
Damping factor @ 100 Hz - 10 Watt ref (Right / Left): 6351 / 6354
Damping factor @ 1 KHz - 10 Watt ref (Right / Left): 6368 / 6365
Damping factor @ 10 KHz - 10 Watt ref (Right / Left): 424 / 424
U can buy taramps from others places I bought mine through a Internet store which was $100,s cheaper thenthen anyone on here , and still had the warranty and used it no problems
IF it's purchased within the United States, show us proof of price and we will beat it if we have it in stock.
Makes 30k amps seem affordable..
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
907
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
9K
Alejandro14
Alejandro14
Texas
Louisiana_CRX
Brendon Jenness
    May 8, 2024
    May 8, 2024
