Which Farad Capacitor should I get
no, that's not enough, pyle has a 7 farad capacitor that will help tremendously, so you can proceed to knockin pictures OFF DA WALL...and I'm sure it's cheaper than that Planet Audio
1 farad caps are basically worthless, I don't run caps myself but if you insist on getting on then get at least a 5 farad or larger, or a Batcap.
A second battery in the trunk is a better option since it can store so much more current than an ordinary capacitor can and are easy on the wallet.
Don't listen to these guys, 1 farad is mooooooooore than enough. There is no way that wiring could help more than a big cylinder power thingy. It made my shit SLAM!!! I went with a Boss 1 farad cap, and my lights quit blinkin n shit. It's also better to get three 1-farad caps than one 3-farad cap, because there is less inductive resistance with the capacitance when you get more.
wouldn't a square one work better? since his subs r square?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Do what you can afford //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The battery is the best way. But if all you can afford is a cap then get a cap you will be ok, get a decent sized one though. like a 5 like others said.
Fa sho...It will send a proper square wave to the square subs, resulting in better output and greater sq (see what I did there?)
i'd rather have a wider SQ and fuller output //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
thaking
thaking
United States
DMP
