Which Brand Of Wiring Is The Best??
wire is wire is wire....RCA's can make a small difference although i have generic brand shielded RCA's and they have done absolutely dandy for me...
i used to think that too, until i found some high quality wire that proved me wrong... however, for the largest percentage of the end user... its all the same, only people expecting to hear a difference will be able to discern the difference. its not justifiable unless youre competing SQ with the most anal of judges... so whatever is cheapest will be best //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for the opinions. I forgot to mention that it'd be between the Stinger HPM series wiring with Stinger Bullett series RCAs, or Rockford Fosgate Type RF series wiring with Rockford Fosgate Matrix RCAs.
Just a FYI: Bullet RCAs : 5.0mm twisted But you dont have to worry about pulling them apart as the ends are already pulled apart enough for any application.
Stinger HPM series power wire is not exactly the cheapest wire out there. Unless you are going for show I would spend the extra money to get the expert series(hexagon shaped wire) which looks really nice. If not, then just get some wire from weldingsupply.com.
Let me know if you want stinger products, I can get you them. PM me
The Anderson's has Audiopipe cable cheap; Found 3-fuse 4/4/4 -> 8/8/8 distro blocks there for $6.75, too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :)
So, got my component amp in today.
LoveItLoud_85
LoveItLoud_85
MN
TeenWolf
