which amp
headtrnr
Hey i am gonna get a re sx 15 and was wondering what would be the best amp
i was thinking the :Hifonics BX1605D , ED Nine.1, Hifonics BX2005D .
the sub will be ported around 3.5cf tuned around 32-35hz
mostly hip hop and rap
i'm not sure about hifonics and have heard that they don't carry the rep they used to. I can tell you that profile ap1000m's pound like a mother and there only $99.00 at etronics. I have 2 running one optidrive 1532D, the amps are almost clipping that sub and its rated at 1300rms, they have 60 amps worth of fuses. so 2x60= 120 x 10= 1200rms. If not, take a look at kole audios new D class, its really clean and I here good things, plus it doesn't have any built in fuses, only the bad %$# amps are usually built like that. usually means that they draw so much current fuses are needed outside the main.
try the ed 9.1 cleanest of the amps you have chosen. also do rated power. hifonics isnt all as bad as stated by others. if you choose to take the hifonics do not crank the gains because it will only cause discomfort for your sub and your electrical system. any way you go that woofer will get quite loud off the power from all the above stated amplifiers good luck and if needed you can pm me with any questions about hifonics. very experienced with the bx and tx line of mono blocks.
headtrnr
headtrnr
Toronto
xbdrx
