When doing an L-port, how do i measure the port?
Just as the title says, im wondering how i measure the port out to do an L port in a box im gonna build. Im familiar with doing sealed and aero boxes but never a slot port. Do i measure the outside of the box wall for port length? Or do i measure the straight part, then measure the other end of the L add and those together to create the length?
Box in question is a 3.6 cube box tuned to 35 hz, port length is around 20 inches. 4"x11" port. Other reccomendations are welcome as well.
When I build any slot ported boxes, I allways draw them out full size on something. I draw a line going down the center of the port the whole length and measure that. Seems to work for me.
measure down the middle of the port...might also want to do a search on "end correction"
I found a few topics on end correction, but nothing that i could understand real well. But heres what i got from it, end correction is something needed when one of the box walls also serves as a port wall, and when that happens half of the port width needs to come off the end of the port? So i would measure down the middle of my port, then instead of making it 20" i would make it 18? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
If the port is 4" wide then you would take 2" off the over-all length otherwise you'd be tuned a little lower then planned. Honestly I don't even do it anymore as it never seems to make much of a diff for daily boxes and most guys like to play the low stuff anyway...
I Like Waffle
North Carolina
mlstrass
