What's the difference between hifonics hfi 1500 and the hifonics zeus 1500?
The Zeus is the lowest line.. The Zeus line is rated by peak, HFi is rated by (slightly exagerrated) RMS. I have a HFi2500d and it does well. I've seen clamp test showing anywhere from 1700-2200w out of it. The Zeus will be lucky to do half the "rated" power.
So to answer your question, no it's actually worth less than the HFi series
That CEA compliant crap is a bunch of horse squeeze.....If you are going to buy a Hifonics amp at least get one of the Brutus series ....I have sold and installed them locally...they seem to do well for the money....
I do have a brutus for my other car. The zeus is an older amp in my nissan I'm about to sell. What is the point in cea compliant if it's crap?
That CEA compliant crap is a bunch of horse squeeze.....If you are going to buy a Hifonics amp at least get one of the Brutus series amps....I have sold and installed them locally...they seem to do well for the money....
The Brutus and Brutus Elite are nice, especially the 2013 models
CEA is a marketing scheme used to sell amps...companies can pick and choose the amp lines that they want CEA compliant.....It doesn't mean the amp will do rated PERIOD!!!..........If you notice a lot of the big name manufacturers like DC, Sundown, AQ, and quite a few others sell big boy amps that are NOT marketed as CEA compliant and they will do rated....So don't fall for the CEA hype.....
Why is this thread so full of dumb??
The Zeus is the lowest line.. The Zeus line is rated by peak, HFi is rated by (slightly exagerrated) RMS. I have a HFi2500d and it does well. I've seen clamp test showing anywhere from 1700-2200w out of it. The Zeus will be lucky to do half the "rated" power.So to answer your question, no it's actually worth less than the HFi series.
Zeus isn't rated by peak. How could it be when it's 1500w rms with 140A fuse? It's just like all the other their other lower price ~1500w HF amps.
HFi was the cheapest line of amps HF ever put out.
Are you just making stuff up?
It's certainly not god's gift to amplifier ratings, but it's infinitely better than nothing. It tells us the amp WILL do rated power at 14.4v and 4 ohms. Why is that such a problem?
There isn't a point. Sort of like peak
Again -- that's completely illogical.
It provides a baseline. MUCH more meaningful that peak/max numbers -- way WAY more meaningful.
Umm, yes, it does -- at least at 4 ohms and 14.4v.
Obviously it's not everything you need to know about an amp, but unless you're completely brain-dead, it helps.
High quality brands don't need it -- it's a basic assumption that they'll do what they say. It costs them time and money to submit their products to CEA for testing. It's pointless for the high quality brands.
The worst thing about cea-2006 compliance, especially with sub amps -- is it doesn't apply to 2 or 1 ohm power output.
So an amp that meets its 400 at 4 rating, for example, can be rated at 800 at 2 and 1500 at 1 but only put out 600/800 respectively and still meet its certification.
Maybe the reason people are so quick to write off the certification as useless is because it takes 3, maybe 4 brain cells to understand it and its loopholes.
Ahmed Johnson
Ahmed Johnson
E-town in the burbs now.
n2audio
