What's it take...db
Anybody have pictures of a trunk setup that does 145+ on music @ around 34hz??
I'd like to get an idea of what kind of power/box(walled, ported, 4th)/setup I'd need to hit the higher numbers on the low bass notes.
my wife does about 143.8 average in her car from the trunk with about 4-500rms give or take the imp rise & voltage drop, also her small power wire. she has stock alt, 1 yellow top only under hood, and 8ga power wire(
i dont see any reason why you should be able to do it pretty easily honestly. just get the install done correctly and the subs & amp you choose should do work
After I get my new amp and electrical finished getting beefed up I'll let you know... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As far as sub and port orientation, it really depends on the car. Firing into the car is your best option in most cases, if possible (not possible without a lot of modification in my and Timmy's case)
Car makes a diff also. If 34Hz is way below your res freq it will be that much harder as you will be fighting cabin gain. My altima with a wall peaked at 49Hz, with a trunk box it peaks at 51hz, so being loud at 34Hz isn't easy.
2 12's or 2 15's would do it pretty easily in the right box. Also have a guy on my team with 4 10's in a 4th order that would do it NP. Was peaking at 32Hz before I redid the port to peak a little higher.
So basically... proper designed and built box, beefier woofers, more power, and tons of deadener... What style box usually produces the best results from a trunk?
cfox10
Rock the house.
cfox10
Tillamook, Oregon
NASTY08IMPALA
