SPECIFICATIONS
* Kapton coil former
* Polyamide coated copper voice coil
* Huge Ferrite magnet with cover
* Die-cast aluminum basket with High Quality Binding Posts
* Paper pulp cone
* Pro Cloth accordion surround
* Vented Pole with dust filter and screen
* Solid composition paper dust cap
* High quality gasket assembly with rubetex seals
* Power handling: 400 watts RMS
* Voice coil diameter: 3"
* Voice coil inductance: 1.40 mH
* Nominal impedance: 8 ohms
* DC resistance: 6.5 ohms
* Frequency range: 35 Hz-2.5 kHz
* Magnet weight: 80 oz.
* Fs: 48 Hz
* SPL: 97 dB 1W/1m
* Vas: 1.6 cu. ft.
* Qms: 4.04
* Qes: 0.31
* Qts: 0.29
* Xmax: 4.3mm
* Net weight: 16.00 lbs
* Dimensions:
* Diameter: 10.3"
* Depth 5.0"
* Cutout: 9.05"
* Paper pulp cone
* Fs: 48 Hz
* SPL: 97 dB 1W/1m
* Vas: 1.6 cu. ft.
* Qms: 4.04
* Qes: 0.31
* Qts: 0.29
* Xmax: 4.3mm
* Dimensions:
* Diameter: 10.3"
* Depth 5.0"
* Cutout: 9.05"
