What would you do?
What would you do?
  • 4-10s
    Votes: 10 33.3%
  • 2 13W7s
    Votes: 1 3.3%
  • level 5 12s and add power
    Votes: 8 26.7%
  • Wall 2 18s
    Votes: 11 36.7%
  • Total voters
    30
Did you try to do the math?
You have to remember a few things. That would be if everything was equal and perfect. The issue is there are many variables and nothing is perfect.
exactly but it helps model the woofer so you can see a tad of the scope on paper. were you might be i thought i point it out well enough that is not dead nuts on but close.
any ways what your guys thought on the z con 15 for this guy think it would work for his budget for two of them? also would it fit his build i know it has more output then the dc xl's and more x max etc. because the spl on the z con starts according to that formula at 101db's at 1w/1m ware they quote that sub at 93spl. now for the xl's it is about 98.96 spl according to the formula the only reason i bring this up is they want number's along with good sound quality. i know the dd3510 are good sub but i do not think they got the output to compete with his xl's at that point he should just keep his xl's. another sub that may work is the fi car audio sp4 15" sub which put out about 96.52 db's according to the formula which is less then the xl's but has way more x max than the xl's. it stuff to think about i do not even know if they would fit in his scion tc...
LosIsATool
LosIsATool
Pensacola, Florida
Chriszle
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
