What would you do between HU or Crossover.
  • 5
a 'line driver' can increase the voltage.stronger signal to amp= louder, maybe not set with a dmm and 'correctly' but it could be a lot louder and you keep your current hu?
A specific amp driving a specific subwoofer/speaker/whatever in a specific installation will only get so loud - regardless of the preamp signal of the source.
Stronger signal to amp does not = louder in this context. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
What it does = is higher output attained at lower volume settings as opposed to the lower preout voltage that was feeding it before. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pfft....my bad?
I would not opt for the inexpensive Focal's (and I've used/use currently - their products extensively in both car and HT applications) and while a...
544
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
bigbangtheory
bigbangtheory
Venus or Mars, just depends.
60ndown
    May 18, 2024
    May 18, 2024
