What to go with in crew cab truck
killintime
Okay so i want to put anywhere between 2-4 subs behind my rear truck seat. Its a 06 crew cab gmc 2500 and i measured what i can fit. Is a box with the following dimensions
Bottom depth 6"
Top Depth 5"
Height 14"
length 54"
These are the max dimensions on box size and still give about 3/4 inch room for speaker movement
i have a audioque 1200 amp already for the subs please recommend what you think i should go with i would like some SQ
What about 4 8inch e8s sealed??? any better options would like to stay under $500 for the speakers ....even open to shallow mount 10s .........but just think getting bass out of 8inch subs would be neat ......what other 8inch subs would sound good sealed and does anyone have any experience with subs ported behind truck seats .....does it work good im not sure i have enough room??
What about 4-5 Tang Band w8-740p each one in about .45 cu ft sealed .......just as good as the e8s?
What will 4 of the tang band w8-740p sound like compared to the 2 12" re se sealed in 1 cu ft a piece ...i just pulled out running off the same audioque1200
Need to order these this weekend any help is much appreciated
1.2 sealed for all four??? so only about .3 cu ft for each one is what you had best results with. I wish i had the room for ported but i just dont see it happening...as far as the 1508ts i think they are made for ported more than sealed right??? Would 4 dd1508ts hit that much harder than 4 tang bands both of them being in a sealed box???
killintime
killintime
houston
killintime
