What to get?
brenTgrillzem
Ok, so right now I have a 12" Fi BL running off a sundown SAE1200 and a set of hertz HSK 165's running off a sundown 100.4D
I have a stock battery up front right now and the lights dim a little bit at night when driving, the voltage drops when the RPM's go down pretty rapidly, so my question is how many feet of 0/1 gauge wiring do I need to do the big 3 and what other accessories do I need or is it just wire?
The second question is what deep cell battery would you go with if you're running the power I'm currently running, which isn't that much but I'm unsure of which size deep cell to get or should I just go with a small 1 farad cap. I know you guys hate caps but I'm just asking so I know the reasons why.
Also the third question is I want a little bit more mid bass, what should I go for? a 6.5 midbass driver and install them right behind the seat in the like behind the seat belts on the bottom of the truck, I have a single cab dodge 98 right now? Or what do you suggest on going with to get some more midbass?
Also I have 4 gauge wire running from the battery to the amp as of right now.
Any other information you need let me know and I'll tell you so you can help me out //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
It's this spot right here:
That's not my truck but I'll take a picture of mine tomorrow, mine can fit a little bit bigger speaker I'm pretty sure
Behind the seat on the right top of the picture
You need to knock out the big three and upgrade your battery. You shouldn't need to put speakers in the rear locations either. Deaden & seal your doors (if you haven't already) and see if that improves your midbass situation. If it doesn't, then worry about upgrading or adding more speakers...
brenTgrillzem
brenTgrillzem
Flo-Rida
brenTgrillzem
