what the best amp for 2 cerwinvega strokers d4 12s
aarock
I am looking at the Memphis mojo but I see it requires a lot of electrical upgrades. I have a Memphis 1000d an thought about getting another but I'm not sure if that will power them good enough. The subs are 2000rms 4000peak. Any suggestions?? Thanks
Ok thanks. I will upgrade my engine battery and the alternator to higher amp I have a 10 farad cap I plan on using. Do u think that would b sufficient enough or will I need a second battery?
Caps are useless, they dont hold a charge at a high enough voltage to actaully help the amp. If you upgrade you alt to like a 180-200amp and do a batt in the back ull be fine.
You could do another memphis 1K, but they would only see like 1200wrms each. Ide atleaste go to an AQ3500 or sundown 3500. But im sure it would sound good on 2 1Ks
aarock
aarock
brooklyn mi
aarock
