what technicaly is a wall
the Answer
DC audio FTMFW
im woundering if the design i made is a wall. i think it is but can someone plz tell me what (a wall) it is exactly. this is for my ranger, it will have a artifical floor and the opening in the bottom is for batts.
It depends, does the top of that enclosure touch the ceiling of the car? A wall is when you literally build a wall in your car, it goes from side to side and from bottom to top.
Look around in the build log section for some threads with "Wall" in the title and you'll understand.
ok then my design is a wall because its 38x48x11Tx17B
Well the dimensions don't matter so much as the question, Does it completely seal off the back of the car? Like as in, will you still be able to use your rear-view mirror? Because if you can, then it's not a wall, lol.
that looks like it would be a wall to me...lol. true story
wall (wôl)
n.
1. An upright structure of masonry, wood, plaster, or other building material serving to enclose, divide, or protect an area, especially a vertical construction forming an inner partition or exterior siding of a building.
2. A continuous structure of masonry or other material forming a rampart and built for defensive purposes. Often used in the plural.
3. A structure of stonework, cement, or other material built to retain a flow of water.
4.
a. Something resembling a wall in appearance, function, or construction, as the exterior surface of a body organ or part: the abdominal wall.
b. Something resembling a wall in impenetrability or strength: a wall of silence; a wall of fog.
c. An extreme or desperate condition or position, such as defeat or ruin: driven to the wall by poverty.
5. Sports The vertical surface of an ocean wave in surfing.
tr.v. walled, wall·ing, walls
1. To enclose, surround, or fortify with or as if with a wall: wall up an old window. See Synonyms at enclose.
2. To divide or separate with or as if with a wall. Often used with off: wall off half a room.
3. To confine or seal behind a wall; immure: "I determined to wall [the body] up in the cellar" (Edgar Allan Poe).
4. To block or close (an opening or passage, for example) with or as if with a wall.
the Answer
DC audio FTMFW
the Answer
sumter county, Fl
csu87
