What model US amp is this?!?!?! Doesnt say anywhere on outside or inside.
BumpinKota
The above item is available to me for $400 (prob a lil cheaper bc i could talk him down) but I have no idea what power it puts out nor does he. Any help on what this amp is/ what power it does/ and how much it would be worth would help out greatly.
Dat's one big biotch......hook er up and clamp er. I'd say if it is in good shape, it would be worth the $400
Im thinking its worth quite a bit more than 400 prob more like 800. But just making sure. Kinda looks like the vlx400
if it has 4 power wires and 4 ground wires its a VLX400 that amp did something like 1200rms x2 @ .5ohm daily or 2400rms @1 ohm mono if not they had a few other amps that had low power at 4ohm but came to like at 1 and under like the 50c they had back in the day. Color is off from the VLX400 I had
there are 2 versions of this amp.
best way I can describe them - cause I **** - is that one will have only 2 circle spools of wire inside it.
and the other one will have 4 circle spools of wire inside it.
the one with 4 is the vxl 400 and suposedly puts out 2400w
the casing should measure 40 inches long.
I realley wanted to buy one - a guy had it for sale on a lowrider site I visit for 400$ but i mised out.
his was purple - and not as sexy looking as yours does. btw - his amp had a clear plexi back to it.
does this one have clear plexi back ? or is it a aluminum sheet pannel ?
looks like a 200hca i hade one of those in a different color , It came out before the vlx-400.Puts out a little less power than the vlx-400.It should have 2 seperate boards inside if you open it up..I got $500 for mine but im sure i could have got more.It should be around 41" lond a few inches shorter than the vlx 400 ..hope this helps.
BumpinKota
BumpinKota
Cleveland, OH
BumpinKota
