What kind of amp/wiring for 2 TDX-12D2s
2 dual 2 ohm subs wire down to either 0.5 or 2 ohms, I would not suggest running 0.5 ohm unless you are very experienced and know what it means to do so. You don't really need to do any electrical upgrades before 1500 watts. I would suggest doing the big three at least though and anything around the 2000w range will require a larger battery, wire, and big three to stay at a good voltage. What's your budget for the amp? You always want to fit the largest wire that the amp can take, bigger is better.
God i miss my 10" TDX i had running of an old school JBL 1200.1. Best setup i ever heard. Love the TDX as they get very loud and sound amazing. I had the older gray cone TDX, not the D9 model.
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
154
387
  • Locked
690
Amp
502
wildcat
wildcat
United States
Capone123
maylar
    Jun 2, 2024
    Jun 1, 2024
