jriley3
Some site said that if i had two amps i would need a distribution block. is this just if i have 2 amps for 1 sub? ive got components in the front with a 2 channel 120 watts rmsx2 powering them then a kicker 300 watts rms at 2 ohm and am searching for an amp to power it. Is it a better idea to buy a mono 1 channel amplifier for it and wire it to 2 ohms or should i buy a 2 channel amp and bridge it then wire it to 2 ohm. what will be the difference between the two? because it sounds like the 2 channel amp will be cheaper and more powerful.
