What is a reactive load?
A reactive load has capacitance and inductance along with resistance...
The reason why it seems that the amp put out more power into that reactive load is because it was 'apparent power' that was being measured... If you accounted for power factor you would see that the amp actually delivered less power then what was measured...
You can think of apparent power as energy leaving the amp which is in turn fed back into the amp; so it never really leaves //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
In a reactive load (one that has inductance and capacitance), you can store and release energy. Capacitors store voltage while inductors store current. In a purely resistive load (no capacitance or inductance) your power is measured by multiplying the current times the voltage. That will give you a power measurement in Watts. In a reactive load, when you multiply the voltage and current, you get the apparent power measured in Volt Amps. This apparent power (VA) is greater than the resistive power (watts) because of the stored energy properties of capacitance and inductance. The phase of the power is also going to be different as the current can either be leading or lagging behind the voltage. This leading and lagging property means that the voltage and current are out of phase by a certain amount. If they're out of phase, then you can't just multiply them together to get your actual power and you have to apply the power factor. The power factor is going to be the cosine function of the angle between the resistive power and reactive power. That leads to the power triangle relationship where you can view power as a phaser on a polar coordinate plane.
So basically, the amp isn't supplying more power under a reactive load but the power it is producing is being stored and sent back by the capacitance and inductance of the circuit elements. The max power an amp can produce (in watts) will never increase under a reactive load.
Impedance vs. resistance... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But resistance is impedance as is reactance. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Impedance is the combination of reactance and resistance. You can't sum the two because reactance is a complex number (remember that imaginary number "i" from algebra? That doesn't just exist in fairy tales) and so we use impedance which has a magnitude and phase.
Mynameismcgyver
Buford T. Justice
Mynameismcgyver
Long Island, Ny
audioholic
