Loudmp5
skyhigh&banginlow
no i have not but i have built and heard for myself I had my sa 10 in 1 cube and when i put it in .5 it was way louder they were both sealed on 1k
Beat me to it. OP its not that confusing at all. If you're going with a bigger box than what is recommended you wont have to send as much power to your sub to achieve the same output because you're stepping up the efficiency of your system.its quite simple.
smaller box =less efficent = requires more power for a certain output
larger box = more efficent = requires less power for a certain output.
the same thing applies to both sealed and vented. in my modeling experiance sealed tends to vary alot more than vented tho.
Matt
Awesome, thanks -01limited- and mat3833 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifBeat me to it. OP its not that confusing at all. If you're going with a bigger box than what is recommended you wont have to send as much power to your sub to achieve the same output because you're stepping up the efficiency of your system.
that is physicly impossible. i mean unless you have found a way to bend and or destroy the laws of physics. and if so please, do tell. i need a 6.5" sub that can play 150DB at 10 hz.....no i have not but i have built and heard for myself I had my sa 10 in 1 cube and when i put it in .5 it was way louder they were both sealed on 1k
not a problem. having a slightly larger box will cause you no issues. it really only matters when you are already pushing more than rated power to your driver, then you can theoreticly exceed the mechanical limits of the sub. but in this case, thats not an issue. if u have the box you are talking about use it.Awesome, thanks -01limited- and mat3833 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
