what gives you bl?
There are two parts to BL. The B which represents the motor strength and the L which represents the inductance. For example: the same motor (same B) with different coils (L1 and L2) will have different BL values. How tight the coil sits in side the gap isn't a direct correlation to BL. The B variables are magnet size, grade, gap size, etc. The L variables are number of turns, height, grade, etc. With that being said: yes there is a best coil for a specific motor dependent upon operations.
Tuan
Tuan
Wow, I just learned something new today! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Sorry, no you didn't...
B is the magnetic force.. L is the length of wire in the magnetic force field..(measured in Tesla-meters)
Stronger magnets, tighter gap, larger coil diameter, and thicker top plates will all increase BL product..
To add to what Haunz's said.
BL is also relative to the coil's resistance. So you cant just look at the BL and know if its high or low, you really have to look at the Resistance too. The formual for calculating the net force factor is BL^2/Re. With that number you can compare any two speakers and know which one has a stronger motor at the small signal. Note: Most speaks have some non-linear effects closer to xmax and the BL can drop dramatically, even as much as 50% which not only lowers the presumed low frequency or high signal sensitivity, but increases distortion. After all BL is simply a curve, so its somewhat inappropriate to compare two curves with just two points.
Sorry guys if my info is incorrect or is poorly written. That is exactly how an tech at one of the major subwoofer manufacturer described it to me as. Let me try to re-phrase: "indirect correlation." L is indeed the length and I described it in terms of physical size. Motor topology and terminology isn't my good area.
Tuan
jusBloud
jusBloud
tre4 N.C.
Toxic Tuan
