What Ga Wire Should I Run From Amp To Sub??
I would say 12g.... Pretty standard, and easy to run..
How many watts? Though I'm not really sure that would matter @ 3f..
1800 watts
n the reason im askin is cuz i couldnt fit 12ga in the terminals....i cant find any 14 ga either....im usin 16 ga as of now....is that gonna be okay?
i use 12 all the way around and have never had a problem...
EDIT: noticed it was u haha, i will come up to SJ and help ya if ya need it...
lol yah finally got around to puttin it in....i got this part figured out but there is another issue i ran into i may need ur help with....i have thread in the subwoofer section about it if u wanna take a look
Why do you need more than one wire in a terminal when wiring in series? Only one connection per terminal in a series configuration. Parallel is a different story and there are a bunch of different way to make that work with only a single wire in the terminal depending on the exact setup.
walkychalky
walkychalky
San Jose, CA
helotaxi
