What do these T/S Parameters say?
_PuNiShEr_
68 Camaro
What size of box would these parameters line up with?
Effective piston area (Sd) 355.4 cm2
Free air resonance (Fs) 34.0 Hz
DC resistance (Re) 3.8 Ω
Mechanical Q factor (Qms) 5.22
Electrical Q factor (Qes) 1.78
Total Q factor (Qts) 1.33
Voice coil inductance (Le) 1.11 mH/milli-Henrys
Equivalent air volume (Vas) 76.8 Liters
Moving mass (Mms) 50.7 Grams/Mmd + air load mass
Suspension compliance (Cms) 432.6 µM/N/micro-Meters per Newton
Force factor (Bl) 4.781 Tm/Tesla-Meters
Sensitivity (SPLref) 87.4 dB/reference 8Ω/2.83Vrms
Thanks
An infinitely large one. That sub screams dipole or open baffle setup though.
What are your goals or plans for this driver? I'm also curious as to what it is too.
Just some cheapo subs i found. That is pretty much what i thought about the box... what would happen if i put it in a small box? Be really peaky around 70-100hz??
http://www.sychosound.com/sychosoundwoofers/manicwoofers.html
Pretty much. Very high Q woofers are going to be peaky which is why they're commonly used for open baffle designs. That way, you can utilize the high Q to deliver a little more low end that you would lose due to the baffle being too small.
Those are not something I would ever run in a car.
Thanks for the heads up. Im looking for a pair of shallow 10's or maybe 8's around 4.5" or so deep. I have a sony XM-DS1600P5 that I plan on using to run them. Im thinking 2 10's or 4 8's i have about 1.6ft^3 to work with. I also need some component speakers. Im selling off a bunch of equipment i have laying around and that is the money i get to use to buy my new stuff. Im thinking i will have aboult $150 for 4 speakers and my subs. Any idea on some cheap subs. I really wish i would have gotten in on the ED $5 subs.
PowerBass PB104d
Fs - 35 Hz
Vas - 45.6 liters
Qts - .68
Splo - 88.7
Dual 4 ohm
150 watts RMS, 250 peak
Not sure of their Mounting Depth
How would 2 of these do in 1.6... i come up with a Qtc of 1.2 I have way more power than i need for them though.
I know the higher the Qtc is the peaker the box is. But can one really tell the difference between say a Qtc of 1 and a Qtc of 1.2???
_PuNiShEr_
68 Camaro
_PuNiShEr_
Iowa
_PuNiShEr_
