what do preamps do
ChrisC
What do preamps do in a headunit?
If a HU only has 2 preamps outputs for the front and rear, can i still add a sub?
so if i have a HU that has 3 preamp outputs, does that mean the HU will power the front,rear,and sub. Meaning i wont have to buy an amp for the sub?
Preamp sends the signal...Im not a technical person. Frost will answer this. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You will need an amp for your sub. You can use a LOC if you only have front and rear preamps.....
Provides the signal needed to drive external amplifiers.
Some decks (like my Alpine 7894) combined the rear and sub pre-outs.
The pre-outs themselves can't power speakers; they simply provide a signal for the external amps that actually drive the speakers.
they are rca outputs on the deck. they send music signals to the amps. the decks with 3 rca's, have a dedicated sub output that lets you specificly adjust the sub. you can run a sub on front and rear outputs, you just don't have a sub control on your deck and if you hook your subs to say the rear, when you fade to the rear you fade to the subs and vice versa.
i have one question abt preamps voltage my p8mp has 6.5 volts preouts and 770 has 4.0 volts preout
whats the difference i know the higer the volt the better but can someone explain it to me how that works...
thnaks
ChrisC
ChrisC
Plano, Texas
newdavid
vegang
vegang
