What do i do next?
rumtillidie
As you can see in my other post i had problems taking out the speaker and all i had to do was use a flat head and it came off when i used a lot of force //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif :eek: //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
now what do i do next do i use the same wires to hook it up to the new speakers? or should i use the wires that cam ewith the speakers(which wire would be better?)
im talking about these wires should i cut them?: which one is + -
well when i was doing it i destroyed the speaker it looks like this now lol:
when it should have looked like this: lol
Its ok to use a little force with those POS stock speakers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As for the connections, just snip off those connectors and strip off the end of each of the two wires for each side. Those two wires are now your negative and positive speakers wires. Either crimp or solder the speaker connections that came in the box to the correct stock speaker wire and you should be good to go. And I believe that usually the wire with the stripe on it is the negative, and the solid is the postive. I might be wrong on that:confused:
no no i installed it already but the speakers isnt working!! the speaker on the left doesnt work and the one on the right works and the front ones work and i wires it correctly!! what happen>?
rumtillidie
rumtillidie
Mississauga Ontario
ace_800
