ahhh, well... i was looking on ebay and they had the kenwood one for 180 when bestbuy sells it for 300... budget... like 200-300$ id rather spend closer to 200 though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif seriously... my whole subs, box, and amp package was only like 175... on super sale.I will second this.
Let us know your budget and we will point you in the right direction.
As far as the problem, I would check and recheck everything. Sounds to me like it's an install problem, if not the amp itself.
The amp is underpowering those subs. Just because the subs will accept more power does not mean they can ruin the amp. This is impossible to my knowledge.
Calm down I didnt say I still want the kenwood lol I just asked what you think I should get? (budget amps such as....)You blow amps by over powering them, bad ground, no fuses, etc, etc.
Go ahead and buy the kenwood.... you have been warned. They make garbage equipment other than their HU's. I have one of their HU's and am very happy with it, but that's as far as I will go with their car audio equipment. There are a lot of budget amps out there that will be way better than a kenwood amp. Especially if you buy used. I honestly think bigger companies like kenwood and Sony think that they can put out garbage car audio, spending no time or thought into the product, just because they are somewhat or very reputable in the Home theater world.
As far as the install goes... I don't know. I haven't seen it. You were asked a couple posts back if the power wire and RCA's are crossing at any point. I don't remember reading an answer to that question. The power wire can be generating noise and penetrating thought the jacket of the RCA's causing noise (since power wire and RCA's typically aren't shielded very well if at all). I would just double check every connection. Making sure that all positive's go to positive and neg's to neg's. Also ensuring no corrosion anywhere including the power wire at the battery. Maybe try changing out your rca's also.
I don't know, it's your dam car! You figure it out!
Yeah... it has gotten HOT before... and what kind of wiring? like... 4g? Rockford fosgate?Thats weird that it was heating up that fast it's a class D amp it should have ran cool or warm at best, what kind of wiring do you run?
ok.I would definitely clean those terminals. Yes corrosion can cause problems. I am not saying that this is your only problem, I am only saying it can cause problems.
4 ga should be good for that low amount of wattage.
Yeah, you can test with a dmm, but like you said, you don't have one. If you get your hands on one it can help solve the problem (if your problem is a powering issue) Us the divide and conquer method. Start at the point that you know there is a problem and work your way back. Look for an inconsistency somewhere. Keep in mind when the vehicle is off you should be sitting at around 12.4 volts. You will get some line loss through 4 ga, especially depending on how long the run is. There is a calculator online somewhere that will tell you how much you will lose per distance depending on the gauge of cable (i'm too lazy to find it, try google).
You might try to run down to walmart tomorrow and buy some cheap rca's and swap them real quick to see if there is any change.
P.S. get a dmm. you need one for car audio. and they are nice to have around the house.
How about something like this?That depends on how much your going to use it. Fluke makes awesome ones. That's what electricians use. I have a chincy POS that my work supplied for me. It tells me the basics, but I recommend buying something a little nicer.
Let us all know how it turns out.
