What dampning products do you recomend
Secondskinaudio.com No better product out there, in mat, foam, insulation or "sludge". I have used 90% of the products out there and this stuff is BY FAR my favorite.
where can u buy damplifier pro without paying full retail.. no online stores carry it..
i'm going to need like 120-140 cu feet of it want to do 2 layers on the floor, 3 on the roof, and 2 layers on doors of my titan
You can check with your local dealer and see if they have some they can cut you a deal on.
Occasionally you can find some one our forum http://www.secondskinaudio.com/forums in the for sale section.
We make a good point of making sure that our dealers do not sell online. This helps protect our dealer and keep our prices & online profits under control.
ANT
I have used cascade products in the past.
So you should continue. One could literally break down products and go spec to spec and tie your brain in a knot. Luckily, Cascade takes a lot of that work out of the way for you. The products have solid engineering and experience behind them across more than one industry (not just vehicles). Their vehicle application guide is right on the money and that's where you should start.
You can check with your local dealer and see if they have some they can cut you a deal on.Occasionally you can find some one our forum http://www.secondskinaudio.com/forums in the for sale section.
ANT
this only makes it more costly for the consumer.. maybe it helps protect the shops but imo they overcharge 5000% on everything else so it shouldnt matter as much..
32sq. ft of dynamat extreme 112 shipped off of ebay
36 sq ft of damplifier pro for 159.00 plus shipping
what excactly is better about the damplifier than the dynamat extreme??
I looked up the auction based on this price and the seller is opening bulk packs and taking one of the sheets out because they say "bulk pack for only the number of sheets you need" and "for most consumers 9 sheets is too much!!!"
Ok, so that's $3.87 per sqft delivered.
The actual whor-ebay cheapest price is $131.95 for an unopened bulk back. That's $3.66 per sqft delivered.
What a bunch of turds.
Do you really think you should be making comments about shops "overcharging" the consumer when you can't even shop eBay correctly?
Who's the real sucker when it comes to buying these products?
Peel n seal. No matter what anybody says thats what i stick with. Have it on my doors and all of my trunk for over 3 years anywhere from -15 outside to over 110F. It works if you put it on correctly.
orangelss
orangelss
Sedalia
JrVtecAccord
