what are my choices for true power?
idfk420
Hello all. Greetings from the south! I just picked up these bad boys today for a cool $150.
View attachment 26552581 sundown audio sa-12 d2 i believe...
little did i know what i actually had purchased. turns out these things are dvc 2 ohm. ok,so now on to the question...
i need an amp thats gonna power these correctly. ive got box and all that,and im not really worried about sq as much as spl... the links i read said these are 600w rms. so i need something with true power to run them. ive got about $350-$400 i can spend. any suggestions?
do you REALLY have a box for 2 sundown sa12s?
but your gonna need to get something that does north of 2k at 1ohm since you can only wire to .5 or 2 and i would not recommend you wiring to .5 becasue thatll be an ivestment of around $1.5k of electrical
were in socal are you?
well you kinda messed up by getting 2 d2 subs, especially sundows yea theyare rated at 600 but the real rating is easily double that. like i said find an amp that does like 2500w at 1 ohm and youll get around 1.2k at 2 ohms. or find a kicker amp those are usually rated at 2ohms but theyre expensive
---------- Post added at 08:55 PM ---------- Previous post was at 08:55 PM ----------
and those subs NEED a custom ported box to specs. you cant just throw them in anything and there
[quote name='C1500martin']Youll need more money for electrical for that, a 0 gauge amp kit is over $100 alone[/QUOTE]
Yep def gonna need some electrical upgrades.What are you putting these in(car) @idfk420 ;
idfk420
idfk420
california
idfk420
