What amp would you choose from these.....
skullsmasher
ca
Ok for my 2 12" dual 2ohm type Rs in a slot ported enclosure in the back of my
ext cab S10, here is the amps I was considering.......
1.$182.51
ORION 2500D MONO AMPLIFIER 2500 WATTS RMS CLASS D
1 X 1200 @ 4 Ohm
1 X 1700 @ 2 Ohm
1 X 2500 @ 1 Ohm
Selectable 12/24 dB/octave variable low-pass filter
Intelli Q bass optimization circuit and remote gain option
2.$295.00
ALPINE MRD-M1005 1800 WATT AMP CLASS D MONOBLOCK NEW 05
Brand New ALPINE MRD-M1005 MONOBLOCK AMPLIFIER
Mono subwoofer car amplifier
500W x 1 RMS (4ohm, 12.0V, 1% THD+N)
700W x 1 RMS (2ohm, 12.0V, 1% THD+N)
700W x 1 RMS (4ohm, 14.4V, 1% THD+N)
1.000W x 1 RMS (2ohm, 14.4V, 1% THD+N)
Max. 1.800W x 1
S/N Ratio 90dBA
Internal, variable-speed cooling fan
Amp Link for single-cable hookup to compatible Alpine receivers
STAR Topology for cleaner sound
Top-mounted digital control center with cover
CEA-2006 Compliant
MOSFET power supply and output stages
Preamp outputs
Time correction 0-10 milliseconds in 0.1ms steps
Phase adjustment 0-180
Turn-on delay
Requires 4-gauge power and ground leads and 80 amp fuse
Extra-large terminals
Fuse rating: 20A x 4
Dimensions: 13"W x 2-5/16"H x 8-11/16"D
3. $325.50
KICKER ZX ZX1000.1 1000 WATT MONOBLOCK AMPLIFIER NEW 06
Brand New KICKER ZX1000.1 1000 WATT MONOBLOCK AMPLIFIER
Class D mono subwoofer amplifier: Provides massive power to your subwoofer without drawing lots of power from your system.
Power output: 500 watts RMS at 4 ohms(1000 watts of peak power at 2 ohms).
Protection circuitry: Protects against short circuits, overloads, heat and reverse polarity.
Expansion options: Speaker-level and RCA inputs make it easy to add on to your system.
Variable crossover: LP(50 - 200 Hz)
Signal-to-Noise Ratio: 95 dB
Speaker and preamp level inputs
Bass Boost: 0 - 18 dB
Remote level control included
4.$299.99
ALPINE MRD-M1005 CLASS D MONOBLOCK AMPLIFIER MONO AMP !
Class D mono subwoofer car amplifier
RMS Power Rating:
500 watts x 1 chan. at 4 ohms
1000 watts x 1 chan. at 2 ohms
Bass Engine® features:
Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
Selectable subsonic filter (off, 15Hz, or 30 Hz)
Parametric EQ variable from 30-160 Hz, ±12 dB
Bass Compensator enhances low-end definition
CEA-2006 Compliant
Preamp outputs
Phase adjustment 0-180°
Turn-on delay
Dimensions: 13" L x 8-11/16" W x 2-5/16" H
90 days Sonic Electronix repair warranty
Amplifier Specifications:
Number of Channels: 1 - Mono
RMS Power (4 ohms): 500 watts x 1 chan.
RMS Power (2 ohms): 1000 watts x 1 chan.
RMS Power (1 ohm): Not Stable
Bridged RMS Power: Not Bridgeable
Peak Power Output: 2000 watts approx.
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: Not Bridgeable
THD @ Rated RMS Power: N/A
Speaker Level Inputs: N/A
Amp Preamp Outputs: Yes - 1 Pair
Built-in Crossover: Yes - LP
High-Pass Crossover: N/A
Low-Pass Crossover: 30 - 200 Hz
Subsonic Filter: N/A
Signal-to-Noise Ratio: N/A
Channel Separation: N/A
Bass Boost: N/A
Bass/Gain Remote: N/A
Fan Cooled: Yes
Fuse Rating: 20A x 4
Warranty: 1-year SE
5.$234.99
POWER ACOUSTIK SL-2000D MONO D 2000W CAR AMPLIFIER
Hi Speed Digital Circuitry
Fully Regulated PWM Power Supply
Four Way Protection Circuit
1 Ohm Stable
Bridging Synchronization
Variable Low Pass 50Hz-150Hz
Variable Subwoofer EQ @ 45Hz
Variable Subsonic Filter 15Hz-40Hz
Phase Switch Q-180
Remote Dash Mount Low Level Gain Control With Cable
Frequency Response: 15Hz-150kHz
S/N Ratio: 100dB
THD: 0.5%
System Distress Indicator
Inputs Sensitivity: 200mv-8V
Dual Mono Speaker Output Connectors
Platinum Plated Heavy Duty Power & Speaker Terminals
Remote Dash Mount Bass Knob Control
Specifications:
1 ch
4ohm RMS: 800
2ohm RMS: 1300
1ohm RMS: 1600
Max: 2000
Dimension: 12.7x11.7x2.3 (L"xW"xH")
6.$154.95
2200 Watt 4 Channel Bridgeable MOSFET Car Amp Amplifier
Four Channel Amplification
4 x 550 Watts MAX Output @ 4 Ohms
2 x 1100 Watts Bridged @ 4 Ohms
Dual Fully Adjustable Electronic Crossovers
Dual Variable Bass Boost: ( 0~12dB @ 60 Hz)
Soft Turn On/Off Circuit
2 Ohm Stereo Stable
Bridgeable Into 4 Ohms
Dual MOSFET PWM Power Supply
Variable Gain Control
Remote Turn On
Remote Bass Boost
Blue Light Illuminated
Heavy Duty Aluminum Alloy Heatsink
Hi/Lo Level Inputs
Gold Plated High Impedance Input
High Level MOLEX Input
Power and Protection LED's
S/N Ratio: >95dB
Frequency Response: 15-30k Hz
THD:
Fully Protected Circuitry
Dimensions: 10.7'W x 2.4'H x 16.7'L
What one woudl you guys go with?
skullsmasher
skullsmasher
ca
Ignatowski
