What amp is suitable??
it's a combined 2000watts RMS, 4000watts MAX
dual voice coil
4 ohms
i was seriously considering lanzar opti2000D but then they're not available here in my country....i talked to the distributor of Lanzar and they're considering the option for a special order for me.....
ok with dual 4 ohm coils on each sub you need an amp that puts out 2000 rms at 4 ohms or 1 ohm. so what amps provide this power at the load from lanzar ? hmm
Well the opti Model OPTI2000D would come close
then you could always use 2 amps in that case each one would need to make 1000 at 2 or 8 ohms and you could go with the Model OPTI1400D or somthing to that affect, just look for the power you need at the correct ohm load.
-Mike
franzb69
franzb69
Manila, Philippines
franzb69
