What amp for mags?
MA P3000.1Sundown SAZ 1500D
IA 20.1
Powerbass XA3000D
Mojo 2000D (Used)
Something Else?
Its 2 Mags... money less than 500 - 600
get the sundown, cheaper than ia and will enable the mags to reach full potential you can wire the sundown down to .5 ohms (does not void warrenty) and have plenty of power.
sundown sundown sundown ... and u should get a pair just for that extra amount of headroom us spl nerds love //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Sundown seems to be the popular choice, but It cant support them at 2 ohms like the others can, so is the .5 ohm warrant what declares it the winner?
Oh and if I could get the Memphis amp would yall not suggest getting it? (Same price Id get for the other amps)
well the reason we are all suggesting the sundown is because they are extremely well built unlike some that you mentioned. second, they are made just for the mags because sundown and stereo integrity have a partnership type of thing going on.
the only other amp on that list that i would choose would be the ia 20.1 but that cost much more and is kind of over kill.
Will running it at .5 ohms still sound as good as running it at 2 ohms?
Well for that amp, it'd sound "better" at .5 ohm. More power going to the subs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You probably already looked at this but, i thaught if you hadn't then here it is:)
SAZ1500D
# 1500 x 1 watts @ 1 ohm
# 800 x 1 watts @ 2 ohms
# 400 x 1 watts @ 4 ohms
# 0.2v - 6v adjustable input sensitivity
# 10 Hz - 350 Hz Frequency Response
# >90 dB dB S/N Ratio
# 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
# Linkable to another SAZ-1500D for up to 3000 watts @ 2 ohms
# 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
# 10 Hz - 60 Hz adjustable 24dB Subsonic Filter
# 0 - 180 degree adjustable phase shift
# 0 - 18 dB adjustable bass boost with 45 Hz center frequency
# Wired Remote Control unit included
# 4x 40 Amp Internal Fuses
# 17" L x 9" W x 2" H
# $599 US Dollars - MSRP
I'll have my hubby explain more of "what it does better" in the morning....its late hehehe....im off to bed:)
BoondockSaints
BoondockSaints
DFW, TX
UndercoverPunk
