What amp for 3 jl 10" w0's?
If the subs are 4 ohm, connect all three positives to one pos. terminal, and all three negatives to one neg. terminal. Two sets are provided on the amp for ease of installation. By doing this, you would have a 1.33 ohm load. The JBL 600.1 does 600 watts rmsx1 at 2 or 1 ohm. That would give you roughly 200 per sub (I know they are rated only for 125, but I am running 300 and they sound great). Hope this helps.
Well for every day use you should go over ther rms that they recmend. But that up to you. If you go for the JL 300.2 that give the all little over 100 each and that would be better for ever day use.
Not to knock the JL amps, but I don't think they are stable below something like 2 ohms. Does anyone know? You won't find too many amps that are stable at 2 ohmsx1 channel, the JBL is stable down to 1 ohm.
jeff there are ALOT of amps stable down to 1 ohm and some lower then that just open thy eyez and look...alot of mainstream are not, because they dont need be like old fosgate 2ohm lowest...now they changed...research more you will learn alot.
Smailliwcm311
Smailliwcm311
MD, USA
Mr. Loki
