csu87
just found this. a blown w7 for 450. what a deal. dont miss out.
http://denver.craigslist.org/ele/1524749356.html
12" JL Audio W-7 Subwoofer - $450 (Highlands Ranch, CO)
Date: 2009-12-26, 1:29AM MST
Reply to: sale-2xrrw-1524749356@craigslist.org [Errors when replying to ads?]
This is the top sub-woofer on the market and will easily provide enough bass for a large SUV (Tahoe, Escalade, etc.). This sub-woofer IS used and does have a blown voice-coil. Being of the JL W-7 series you can send it into JL Audio in order to have the voice-coil repaired (or through Car Toys or another dealer if you wish). This sub-woofer retails for $1000 new so this is a heck of a deal.
Specifications:
Free Air Resonance (Fs): 27.2 Hz
Electrical “Q” (Qes): 0.514
Mechanical “Q” (Qms): 7.807
Total Speaker “Q” (Qts): 0.482
Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters
One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm
Reference Efficiency (no): 0.249%
Efficiency (1W/1m)**: 86.2 dB SPL
Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m.
DC Resistance (Re): 2.47 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.14 cu. ft. / 4.0 liters
Net Weight: 45 lbs. / 20.4 kg
