what 8" midrange?
just found some Jl Audio ZR's i could feed them 100 rms @ 4 ohms
anyone use these? there actually not that expensive
or what ID mid does everyone talk about?
What bandwidth are you wanting them to play? If you're trying to run a 2-way setup with 8" mids, you'll be hard pressed to do it well without some horns. With an 8" mid you're limited to about 1.25-1.5khz, which make finding a tweet to match very difficult(hence the need for horns).
An 8" midrange would be even too much at home, perfectly on-axis...I have 6.5's playing full range, anything above that and it'd get ugly...
Then again, if the words "keeping up" are involved, chances are you aren't too concerned about staging accuracy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
those are 8 ohms tho ?
how do you amp them correct power at 8 ohm value ?
side note -
I have been verry much thinking of the 8" powerbass mid woofers
I have been finding a fiew sets at my local crap car audio stores
for about $40 each one. verry tempted in them.
I forget exactly - but the frequency response of them is wide as heck.
the amp just runs @ 8 ohms.
unless u have say 2 mids per door, and u can wire both 8 ohm mids for a 4 ohm load on your amp
either way those eminence will get loud, as will B&C, selenium, etc
Gavriley2007
Gavriley2007
MI
orangecounty1
