Were To Put Chassis To Engine Block(PICTURE)
that bolt is a good ground, actually the main bolt the alt grounds thru
Where the heck is your battery? If you follow the wires that terminate at the negative terminal, you will find that one goes to the chassis somewhere, and the other to the engine block. You can use those exact same spots.
X2...
While the alternator bracket in most cases is sufficient, one needs to consider that the brackets are not always made of metal, but a composition of hard plastic and metal.
my battery is in the right front corner. i already did the battery to chassis so your saying that i could use that same spot for engine block to chassis?
i found another small wire grounding to my chassis by the engine idk wat is that its smaller than the other normal stock wires, I was thinking that maybe my car has a 'stock engine to chassis wire'
MmatsDude
MmatsDude
Los Angeles CA
ultimate157
