Weight of Kicker 1/0 Spool?
Most likely buying some... System is just about finished, and need the wire to run so that when the subs show up it will be ready to wire them up and play it.
Just a rough idea. Im getting a killer deal on some from a guy on a local forum. $125 per spool. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
If the person takes it off the spool, it will fit in an $8.95 flat rate priority mail box.
Exactly, thats how mine was shipped to me. paid 100 shipped for 50ft.
I got a good deal. //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
Im buying 3 spools though...
3 $8 packages is still going to be way less than 90lbs regular rate.
If he can't fit it in the $8 ones, then a spool will fit in the $12 flat rate box just fine... I mailed out 2 of them for $12 a piece, from MA to LA
874
galacticmonkey
Wants a button like that.
galacticmonkey
Tampa, FL
ultimate157
