We burped the SD12kD in 16V
Just explaining:
We used a lot of power resistors to keep the impedance around 1 ohm. The noise you see is the resistors heating inside the water container.
You can estimate the impedance by dividing the voltage by the current, so the actual impedance was 1.043 ohm.
snoopdan, Ill do the same on my comp cars ASAP, the power will be the same, since you have a impedance of 1 ohm.
negative, the power out of 2 amps will be 36kW at 0.5 ohm.
murilo
murilo
Winnipeg
Annnarbor84
