subzero
http://www.shopping.com/xPF-Power-Acoustik-PS1-3000D
Subs = T5 12 x2 2 ohm coils. What is your take on this ?
I will be redoing the box for the subs. I need to know if I should seriousley think about a different amp.
Burned up a set of coils already and had to recone. So I am trying to take a overview of the equipment and applications to determin what areas need to be addressed.
The car is a cavalier coupe 03, box is a slot port on side tuned to 32hz, maybe 40 sq in port area, volume is 3.25 cubes. Subs faceing rear port drivers side. Dual battery setup.
Should I try box facing forward or to the side? dependant on the size of the new box , which I and going to try for as close to 6cubes as possible tuned to 34 with about 90sq in port area. and resin the inner box with some insulation.
Let me know what you think cuz I gotta save for new amp if needed.
