Want a "budget"? Amp good to .5ohm... Got around $500 to spend. Really like the scv4000 but way out of my budget right now..
how much power are you looking to get?Want a "budget"? Amp good to .5ohm... Got around $500 to spend. Really like the scv4000 but way out of my budget right now..
Depending on his power needs, i was going to suggest possibly 2 of the amps i have and he can strap them. I have a Soundstream Ta1.3000d and its .5 stable and really not that bad wired down .5ohm and i had stock 70a alt with 1 6yr old group31 agm in back, 1 run of 1/0 and unless i competed when i drove i stayed around 12.7v, and voltage drop to 11.3v lol but again stock alt. Mine is currently wired to .7 ohm but i had it wired to .5 previously for over a year.What's your electrical like? That determines how much power u can run... A amp at .5ohm is gunna be power hungry
getting 4k for $500 will be semi difficult.... how much power are you actually wantingI got a brand new 270amp mechman with the big 4 on 1/0 wiring and I'm going to be ordering a xs power XP?3000 havent ordered main power cables yet due to not knowing how many strands ill have to put to the amp. I heard the zv4's can take a daily of 4000 watts. So...around there. First real build.
also just because a sub can take it doesnt mean you need it to power it....I got a brand new 270amp mechman with the big 4 on 1/0 wiring and I'm going to be ordering a xs power XP?3000 havent ordered main power cables yet due to not knowing how many strands ill have to put to the amp. I heard the zv4's can take a daily of 4000 watts. So...around there. First real build.
how many subs and what coils? Do you have 1 Dual 1ohm sub or 2 Dual 2ohm subs?Between 2500 and 4000 I suppose
