w6v1 vs w6v2
Okay, the JL w6v1 is like (in construction) a w3v1 with a double stack magnet and a pole vent. So the w6 would theoretically have better cone control etc...
W6 v2's have the fancy basket/cone like the w7, but as Knockin says they really don't seem to differ much other than that.
However, w6v1's are hard to find in good shape and expensive. People tended to beat them like red headed stepchildren.
Once again they are the same thing!
They are totally and completely different woofers in every conceivable way.
12w6v2
(Fs): 25.0 Hz
(Qes): 0.480
(Qms): 7.100
(Qts): 0.450
(Vas): 2.82 cu. ft.
(Xmax): 16.5 mm
Sensitivity (1W/1m)**: 85.9 dB SPL
(Sd): 77.8in^2
(Znom): Dual 4 ohm
12w6(v1)
Fs: 20.9hz
Qts: .433
Qes: .462
Qms: 6.897
Vas: 5.73ft^3
Xmax: 11.1mm
Sensitivity: 86.9db
Sd: 82.5in^2
Znom: Dual 6ohm
The W6v2 is a better subwoofer in both output and sound quality than the W6v1
12w6v2
(Fs): 25.0 Hz
(Qes): 0.480
(Qms): 7.100
(Qts): 0.450
(Vas): 2.82 cu. ft.
(Xmax): 16.5 mm
(Sd): 77.8in^2
(Znom): Dual 4 ohm
12w6(v1)
Fs: 20.9hz
Qts: .433
Qes: .462
Qms: 6.897
Vas: 5.73ft^3
Xmax: 11.1mm
Sensitivity: 86.9db
Sd: 82.5in^2
Znom: Dual 6ohm
Yeah, i was wondering, thanks for clearing that up!
with 2 w6v2's I am able to achieve what i was doing with 6 w3's in JL's enclosures.
so you are comparing apples and oranges here! Even though same company 2 different products!
w6v2's for the win
Neither are loud subs but yeah, both have great SQ, ive heard both, v2 is louder than the v1 in general (all alignments ive heard with v1 where sealed where as ive heard ported and sealed for the v2) but over all neither are loud, but once agian both have good to great SQ. W6v2 are top notch SQ subs.
shiipseki
shiipseki
LA, CA
Cbass
