I just had a shop tune my system using an RTA with the H701 (never had tuned before thosuhgt I was in the ball park). 4-hours later the system sounds sick!!! Totally different then what I had, they kept the original setting on one of the presets. The dancing graph is now nice an flat, the tuned each corner individually and setup the 5.1 for me. I also just purchased the KWE-610A optical cable and installed as well (what a peice of garbage for $100). The connection to 701 is not tight and will basically fall out! I had to search for weeks to find the correct tight fitting cable for the D106 that uses a regulat tolink connector on both ends!
Anyway the system is and DSP is awesome if you know how to use it!
