solidcrowd
12" Fi BL (P chamfer & flatwind coil)
DUAL 1
Fs: 38.7 Hz
Re: 0.75 Ohms/coil
Qms: 05.79
Qes: .39
Qts: .37
Mms: 177g g
Cms: 0.96mm/N
Sd: 481cm^2
Vas: 30.9 l
Spl: 88.0dB 1W/1m
Bl: 12.8 N/A
Xmax: 21mm
Rms: 1000W
Sealed box: N/A cuft
Ported box: 1.8-2.5 cuft @ 30-37Hz
or
12" RD elite spl
Param. 12D2
Fs 37.7 Hz
Qms 4.64
Qes 0.129
Qts 0.126
Mms 206 Gram
Vas 18.6 L
Re 4.0 Ohm
Sd 550 cm2
BL 31.43 N/A
Xmax 10.0mm
RMS 900W-2000w RMS depending on your application
Mount Depth 7.17"
Outer Basket 12.375"
Cutout 11.125"
Powered with 1115 rms @ 2ohms
2.2 cu.ft. @ 32hz
Please help me decide, which one will get louder and still have some good sound quality. Price is really close so that doesnt really matter to me.
DUAL 1
Fs: 38.7 Hz
Re: 0.75 Ohms/coil
Qms: 05.79
Qes: .39
Qts: .37
Mms: 177g g
Cms: 0.96mm/N
Sd: 481cm^2
Vas: 30.9 l
Spl: 88.0dB 1W/1m
Bl: 12.8 N/A
Xmax: 21mm
Rms: 1000W
or
12" RD elite spl
Param. 12D2
Fs 37.7 Hz
Qms 4.64
Qes 0.129
Qts 0.126
Mms 206 Gram
Vas 18.6 L
Re 4.0 Ohm
Sd 550 cm2
BL 31.43 N/A
Xmax 10.0mm
Mount Depth 7.17"
Cutout 11.125"
2.2 cu.ft. @ 32hz
