Viper 791xv probs
grtn316
A month ago, I was using my truck as a radio. Well, the battery died after about an hour (forgot to turn it on) and then the truck tried to turn over. It eventually stopped. After I jumped my truck and got it started, the remote lost signal to the brain. I am not sure exactly how to program the brain to see the remote but I have tried a few things. Does anyone know the exact steps to program the remote to the brain or should it never lose signal? Could I have a fuse blown on the brain or something? My installer is not around and so I gotta figure this out on my own.
Thanks for your help.
It sounds like the transmitter may need to be reprogrmed.
Open door
turn ignition on
press overide once
press again and hold
larm will chirp once
press lock on remote
alarm will chirp again
relese switch and turn car off
Try that and let me know.
overide is the valet switch
Open door
turn ignition on
press overide once
hmm...
I did it exactly the way you said. I tried it with the valet switch on and off. Neither worked.
When I held the button in and it chirped, I saw the LED light flash. While holding it in and pushing the lock button, the remote just beeped like it was out of range. I tried this several times and also the other buttons.
Thanks!
hmm...
Thanks!
when you push it and after you hear the chirp let go of it and then press on the pager the lock button and if it doesnt work then its probably something else
grtn316
grtn316
Midland
grtn316
vegang
vegang
