Viper 5900 w/ 515R Siren -> 511T Siren (PROBLEM)
AW_STi06
8
ATX
Ok, so I've had my Viper 5900 security system installed for about a year or two. I have gone through two 515R's and am now trying to install my new 511T "super loud" siren. The 511T siren comes with 4 wires (red, black, purple, and blue) whereas the 515R has another 4 wires (red, black, purple, and green).
The problem:
It all happened after I replaced the first one that died mysteriously. I bought another 515R and installed it. Problem solved...for a few months. I replaced my car battery and about a month later the siren just randomly starting going off. It had been going off for a while I think, cause when I went out to my car, the siren sounded like a dying cat. My car started right up first time, so I just figured it was a dud battery. Later my car battery died and had to be replaced //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
I go to install my new siren today and see that the new siren has a blue wire instead of the green wire that is in the wiring harness.
The question:
Why did two of my 515R sirens die?
How do I wire the new siren?
i will look into it at work but i would start with trying the red and black. what are the purple and green currently hooked up to? to me it would seem like hook purple to purple and blue to green.
That's exactly what I did. I'll have to look into it further after work.
I have seen plenty of those backup battery sirens go bad; don't know why but they all seem to do the same thing, go off randomly and drain the cars battery.
Luckily mine hasn't though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Oh, and great choice of color on your car //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank you, you too!
Looked at the installation guide last night for my alarm. Didn't really help me too much.
The info for the siren would be under the sirens manual.
Im pretty sure its:
red - 12 volts
balck - ground
purple - positive siren output (brown from alarm)
green - negative siren output (used for other alarms)
Im pretty sure its:
red - 12 volts
balck - ground
I did that and now my viper fob won't communicate with the car alarm. Do I need to re-program or reset my alarm?
I just re-read your post after talking to someone in Canada with DEI (who of course doesn't have the wiring diagram) and noticed that you both mention the brown wire. Here is what he had to say.
"The green wire from the security system is the negative door trigger input wire.
The only siren output from the security system is the brown wire and it's a positive signal.
I don't have the 511T wiring guide to help you."
I don't have a brown wired output. I only have the red, black, green, and purple. No brown.
Im pretty sure its:
red - 12 volts
balck - ground
This is correct. The brown wire in question comes off of the alarm, not the siren. On the siren, hook the red to constant, black to ground. Run your brown siren output wire from the dei alarm to the purple wire coming out of the siren. Tape off the green wire, problem solved. Funny I have one of these things and was trying to hook it up today lol. Im not so sure of that 511t for the model # as I cant find any info for it online. I do know its one helluva siren. My question is what do I need to do to make it work constantly on my factory alarm horn that blows intermittently. Surely theres some delay relay or something I could build to put on it. Any ideas????
The problem is that I have no brown wire to hook up to.
Look at your alarm installation manual. Look for the siren output. If it's a + output, connect that to the purple wire on the siren, if it is negative, connect it to the green wire. It's not difficult.
AW_STi06
AW_STi06
ATX
AW_STi06
