Viper 5701 sucks
GI JOEY
Paid 4 by ur tax $
My Viper 5701 wont respond back to the 2 way fob. I have tried disconnecting the vehilce bat, pulling the 15 amp fuse, all 3 30 amps, tried a new antenna cable and antenna, tried using a 10k ohm resistor wired within an inch or 2 from the brain on the blue antenna wire, deleting the remotes, relearning them. Still nothing.
All the functions of the remote work just fine as a 1 way but I get the out of range error tone and flashes. What to try now?
Did you install the unit yourself? If so where did you buy it from. I'm sure there are still a ton of the bad 5701s floating around out there. If you call DEI with the # off of the brain they should be able to tell you if it is one of the bad units or not
Yes, many bad brains out there. The resistor trick only seemed to work for a short time. New antenae and antenae wire is the best fix. If your brain wasn't sent in for the newer revised version it should be.
GI JOEY
Paid 4 by ur tax $
GI JOEY
Amarillo, Tx
AVX Mike
