Vifa BC25SC06-04 1" Textile dome tweeter
c_nitty
Item(s) for Sale:Vifa BC25SC06-04 1" Textile dome tweeters
Item(s) Description/Condition:Used Vifa BC25SC06-04 1" Textile dome tweeters
Smooth-sounding compact soft dome tweeter with high output and response past 20 kHz. Neodymium motor, heatsink fins, and round faceplate.Pre-coated textile diaphragm for improve consistency
Neodymium magnet
Heat sink on magnet for increased power handling
Ferrofluid cooling for increased power handling
Slight horn loading for increased efficiency
Impedance 4 ohm
Resonance frequency (fs) 1350 Hz
Sensitivity (2.83V@1m) 96dB
Power handling (IEC 18.3) 50 watts
Qms 2.37
Qes 2.3
Qts 1.26
Re 2.9 ohm
Bl 1.7 Tm
Mms 0.35g
Cms 0.27 mm/N
Sd 6.8 cm2
VC diameter 25mm
VC height 1.8mm
Gap height 2mm
Flange diameter 70mm (2.76")
Cut out diameter 44mm (1.75")
Depth 32mm (1.25")
Price:$22 shipped
Now take them 6w4p's I gave you and that 3 way crossover put them with these and get your shiz ACTIVE son.
Will Do , gonna run these on the PPI PCX250 i got and gonna do baffles for the seleniums (which will be running 80-4K off my sony 5540) when i build my box next weekend.
c_nitty
c_nitty
Houston,Tx 77044
Bassin Buick
